Example Code
Custom Text File Logging for Real-Time Targets
Code and Documents
Overview
This custom logging is extremely helpful when debugging crashes and hangs on embedded systems. It will log what section of the code is executed and when. This allows the user to know what the last process called is before a crash or hang occurs.
Description
This VI is a simple write to text file that allows for sections of code to be executed in between. This can be extremely helpful when code is executing serially on your embedded controller.
  1. Place on block diagram.
  2. Separate code into sections to narrow down specifically when crash or hang occurs.
  3. Review the log that is created using FTP, SFTP, or WebDAV.
Requirements
Software
LabVIEW 2013 SP1
Hardware
CompactRIO, an embedded cDAQ running LinuxRT, or a PXI controller run Phar Lap.
Additional Images or Video
The log on a Linux cRIO will look like the log below with the section and when the section executed.
When the log is generated through Linux and viewed in Windows it will look like the log below due to differences in line breaks between the 2 operating sytems.
Contributors
