Example Code
Custom Color Ramp in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example allows you to easily set the colours and scale for a colour ramp control using the color box constants.
Description
Using property nodes it is possible to modify the appearance of front panel objects. By creating a custom cluster containing scale and colour values for ease of use and then restructuring it into individual cluster pairs it is possible to add as many points to the scale with different colours as required.
Requirements
  • LabVIEW 2013 (or compatible).
  1. Choose the colors for High Value, Mid Value and Low Value.
  2. Choose the corresponding values for these colors.
  3. Run the program.
  4. Use the Value In knob to see how the color changes accordingly.
  5. Press the stop button to exit.
National Instruments - Tech Support
