Example Code
Crop and Save a 24-bit Bitmap Image Using LabVIEW
Code and Documents
Overview
This VI crops and saves a 24-bit Bitmap (BMP) image.
Description
This VI uses the Picture Functions VIs, Graphic Formats VIs and Array Palette Functions to retrieve, crop, and save BMP Images.
Requirements
LabVIEW 2012 (or compatible)
  1. Open the VI.
  2. Specify the path of a 24-bit Bitmap (BMP) Image.
  3. Specify the Region Of Interest that you want to crop through the parameters XStart, XWidth, YStart, and YWidth.
  4. Run the VI.
  5. Observe the cropped Image being displayed in the VI.
  6. Observe the cropped BMP Image that is saved to disk in the same folder as the original BMP Image.
Sincerely,
Jason Daming
http://www.ni.com/support
