This example uses the event structure, new in LabVIEW 6.1, to create an object you can drag on the front panel. The front panel has a Boolean indicator that you can drag at run time. Dragging the Boolean indicator over Exit will light up the indicator. Dropping the indicator onto Exit will exit the VI.
