This example uses the CW3Dgraph ActiveX Object to create a Waterfall plot using. The VI uses Express VIs to generate a sine wave and calculate the FFT Power spectrum. The result is plotted in a 3D graph using a feedback node to build the Z-Matrix. A shift register is used to build the Z-Matrix.
