1. Overview:
This example VI shows how to read data from one column of a spreadsheet file and create a histogram from the data
2. Description:
This example shows how to use the General Histrogram.vi in order to build a histrogram from a spreasheet. In this case the spreasheet is a .txt file where the data is ordered in columns and the data is retrieved as a 2D Array. In order to get the histogram from the first column, the 2D Array mus be trasposed.
3. Requirements
4. Steps to Implement or Execute Code
5. Additional Information or References
VI Block Diagram
Here's a more developed approach I had to do:
