Example Code
Creating a Boolean control with pictures
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how to create a Boolean picture control.
Description
Upon opening the Boolean with pictures.vi (or Boolean with Pictures 2012 NIVerified.vi ), the user will see the white button stating "light is off". When the program is run, this white button can be selected, and the image will change to say "light is on". Additionally, the Boolean indicator will toggle on. This white button was created and saved as a .png using Microsoft Paint.
Requirements
  • LabVIEW 2012 (or compatible)
The picture was imported into the attached custom control with the following steps:
  1. Create a Boolean control in the top level program.
  2. Verify that the picture wanted is copied in the clipboard.
  3. Right click the control » Advanced » Customize... (This will open a new window).
  4. In this window, right-click the control » import picture from clipboard » choose the true, false, or decal (always visible) case
  5. Run the Boolean with pictures.vi (or Boolean with Pictures 2012 NIVerified.vi ) to test this boolen control with pictures.
Front Panel
When creating the control, you can also go to the top toolbar. Select Edit » Import Picture from Clipboard. This will put the picture on your VI; however, this does not tie the picture to a specific state of your control. The picture will be visible, but will not chance when the control changes state, shape, or size. It just remains as a visible item in the control that can be resized separately
Lea D.
Applications Engineering
