Example Code
Creating File Names Programmatically Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to programmatically create file names with a standard pattern.
Description
This example create a file name that includes a test number, and a time stamp. The test number in the file name will be programmatically incremented every time a new file (or test) is created.
Requirements
Software:
  • LabVIEW 2012 (or compatible)
1. Run the VI.
2. Push the "Write a New File" button.
3. File name will be generated related to time and iteration.
Eli S.
Comments
Todd S.
NI Employee (retired)
on
Good stuff, thanks!
Todd S.
LabVIEW Community Manager
henry2212
Member
Member
on
Hello!
How do you save this file into particular location
Thank you
