Example Code
Create custom right click drop down menu using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates how you can customise the right click in your LabVIEW VI. This is very usefull when you would like to right click on a control or indicator and depending on the option the user selects (which are specified from the programmer) different functionality can be observed.
Description
Requirements
Software:
  1. LabVIEW2012(or compatible)
  1. Download and run the VI.
  2. Follow the comments in both front panel and block diagram to get a better understanding.
VI Block Diagram
Comments
JUSTBEGINE
Member
Member
on
hi
regarding the same... i would like to mention my query .. i want to perform 3..4 tests using labview.. each test will include a seperate VI .so my question is , it it possible to make function which will allow user to select the required VI from a drop down list in same labview window/VI
THANKS IN ADVANCE...!!
please help me...
