Overview
Create and add a table to a Word document using the Report Generation Toolkit.
Description
This example shows how to create a word document using the report generation toolkit. It then shows how to create a table and embed it into the word document. Lastly, it shows how to query availble printers and print the document to the default printer.
Requirements
LabVIEW 2012 (or compatible)
1. Configure the header that you would like to insert.
2. Configure the data that you would like to use.
3. Select if you would like to print the table.
4. Run the VI.
