Overview
This VI shows how to use the analog input sample clock to serve as the time source for a timed loop structure.
Description
Inside the timed while loop of this VI is an analog output. In addition, Finished Late Output Node was included, if the code inside the timed while loop takes too long to execute, a true will be passed to the Finished Late? indicator.
Analog Output Sample Clocks are not supported as the timing source for a timed while loop structure.
Requirements
VI Snippet
