Overview
This example VI creates a Sub-Array based on whether or not values are above or below a threshold.
Description
10 random doubles are generated and then compared to a user-defined threshold. The user picks if the values must be above or below. Then a sub-array is built based on wether or not the values are above or below the threshold, based on user input. Shift reigsters are used to store the sub-array as it builds. Before the first loop, the array is initialized. The array either stays the same or adds a new value as the loop iterates.
Requirements
VI Block Diagram
