Example Code
Create New File Every N Minutes
Code and Documents
Overview
This example VI Illustrates the use of Seconds To Date Function to create a new file every N Minutes.
Description
This VI demonstrates retrieving a specific target's information using RT Get Target Information (All) and a specific information field. This field is used to filter the discoverable Real-Time targets for a specific target's information. Out of this specific target's information, specific fields can be unbundled such as the IP address. The "DNS Name" field used is the same as the target's "Hostname" in Measurement & Automation Explorer. This same technique can be used to applied to any field in the cluster of information returned by RT Get Target Information VI. Also, this example can be further modified to return information for the set of matching targets instead of a single target's information.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Open the VI " Create New File Every X Minutes 2012 NIVerified.vi"
  2. Input a time interval.
  3. Run the VI.
  4. Check the generated files in default data directory.
VI Snippet
Comments
MartinOZ
Member
Member
on
This example fails if minute jumps from 59 to 0!
