Overview
This VI demonstrates how the Report Generation VIs can be used to generate HTML reports that include the Front Panel image of the Create Reports with FP Images VI or another VI on disk.
Description
In LabVIEW you are able to generate HTML reports that include images. This VI will always generate a report for itself when the user clicks the Finish Test button. This example uses an event structure for asynchronous control. The block diagram code can easily be added to existing VIs in order to implement this feature without requiring any code changes.
Requirements
VI Block Diagram
Thanks for posting! Could you please rename your attachment to include the LabVIEW version? "_lvXX.vi" would be fine. Also, include a screenshot of your code if you have one.
