Overview
The acquisition sample rate of a DAQmx task determines the amount of data collected over a given period of time. Sometimes the sample rate is hardware-limited, and the user would like to have less data to log or process. This VI allows the user to create a new waveform of data based on the sample rate and number of samples per read.
Description
The user selects a physical channel (a simulated device can work fine for this), choose the sample rate, and chooses the samples to read. If the user selects 10000 S/s, reads every 1000 samples, then the read rate would be 10 reads/s. During every read, the user has the option to average the samples read, take the first point of the samples read, or take the last point of the samples read. A new waveform is constructed from the downsampled data. This waveform is plotted along with the raw data waveform to visualize the effect of downsampling.
Requirements
Software
Hardware
