Example Code
Create Custom Linear Scale for Each AI Channel in LabVIEW Using DAQmx
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This VI shows how to create multiple AI channels with a custom linear using a for loop in LabVIEW.
Description
Thisi document is used to create multiple AI channels with a custom linear using a for loop in LabVIEW.  You will have to input the physical cahnnel for each channel into the channel array, along with the scaling coefficients.
Requirements
Software
  • LabVIEW 2012 or compatible
  • NI-DAQmx 9.5.5 or compatible
Hardware
  • NI Multifunction DAQ Device
  1. Configure the parameter for the right channel and device
  2. Connect your hardware appropriately
  3. Run the VI
Adam
Academic Product Manager
National Intruments
