Overview
This VI shows two approaches to count a specific character within a string.
Description
This VI shows two different ways to count how many times a character occurs within a string. In a first way, LabVIEW converts the string to a byte array and then indexes through each byte using a For Loop. LabVIEW compares each byte to the *. In a second way, LabVIEW uses a While Loop to iteratively parse through the incoming string. The example uses * as the character to search for.
Requirements
LabVIEW Base Development System (or compatible)
1. Run the VI
2. Change the string by adding more characters with *
3. See the change
delete
What about something like this:
Search and Replace String tells you and (I'm guessing) is probably no slower especially if you set the replacement string to be the same length as the search string:
