Example Code
Counting Files with Specified Extension Type in a Directory Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
The example counts all the files in a specified directory with a specific file extension.
Description
The example counts all the files in a specified directory with a specific file extension, when you try to counts the number of specified file, use it!
Requirements
  • LabVIEW 2012( (or compatible)
  1. Specify the folder that you would like to search in the "Folder Path"
  2. Select the extension type that you would like to search
  3. Run the vi
Front Panel
VI snippet
Comments
GregSands
Active Participant
Active Participant
on
A  better way to do this would be to use the "pattern" input on List Folder, so you only get a list of matching files, and then simply use Array Size to determine how many there are.  It will be much quicker, and use less memory as well.
Also, if you decide to use a For Loop, you should definitely only read the RingText once, not on every iteration.
