Example Code
Counter Pulse Generation and Frequency Measurement Loop-back Test
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview:
Demonstrates on internally routing digital pulses generated from a Counter Output to the Counter Input and updating the digital pulse frequency on the fly.
Requirements:
  1. LabVIEW 2012 or compatible.
  2. NI-DAQmx 15.5.1 or compatible.
  3. DAQ device with at least 2 counters.
Instructions:
  1. Specify all control values on the front panel.
  2. Run this VI.
  3. Verify the pulse frequency from the indicator.
Block Diagram Steps:
  1. Creates channel to generate digital pulses.
  2. Sets the channel to be continuously sampling data.
  3. Programs the hardware as much as possible according to the task configuration.
  4. Transitions the task to running state to begin generation.
  5. Allows the user to update the pulse frequency on the fly.
  6. Clears the task and displays any error occurs.
  3. Internally route the generated signal to the default source pin of the counter.
  5. Continuously updates the frequency measurement on the front panel.
2017-05-31_14-33-32.jpg2017-05-31_14-33-32.jpg2017-05-31_14-33-57.jpg2017-05-31_14-33-57.jpg
Sean Ferguson
Application Engineering Specialist | RF and Reconfigurable Test
