Example Code
Correctly Sized .NET Month Calendar Example Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
LabVIEW 2012 and 2013 have a known issue that automatically incorrectly resizes the MonthCalendar .NET control when the VI is running. The example uses the Container Bounds of the MonthCalendar Property Node to correctly resize the MonthCalendar when the VI is running.
Description
The example provides a correctly sized MonthCalendar .NET Control. In addition, a Property Node is used to circle the current date on the calendar, number the weeks, bold chosen dates annually, and allow the users to set the first day of the week they would like to set for the calendar.
In general, to create a correctly sized MonthCalendar .NET Control, create a MonthCalendar Property Node and set it to Container Bounds>> All Elements. Then wire a constant (approximately 200) that will show the full calendar when the VI is running.
Requirements
  • LabVIEW 2013 (or compatible)
  1. Download the VI.
  2. Run the VI
Additional Information or References
VI Block Diagram
