Overview
This Example VI shows how to copy an Excel template when using the Report Generation Toolkit.
Description
The example generates a new report and a new worksheet in that report. A tab-delimited .txt copy of the template worksheet is read into the VI using Read From Spreadsheet File.vi as a string array and inserted into the new worksheet with the Append Table to Report.vi. This makes a copy of the template worksheet headers on the new worksheet. The Excel file and tab delimited files are found using a relative reference, so if any projects or other VIs are open when you run the example, it will search the wrong directory for the Excel and tab delimited files.
Requirements
Software:
VI Block Diagram
