Example Code
Copy Data Between 2D String Array Controls in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Code that shows how to copy data from one array and insert it into another, using Event Structures and Arrays.
Description
This code demonstrates how you can use a 2D String Array with an event structure to copy data between two 2D String indicators. When we press the Copy Data button the data in the selected part of the Generated Data array is stored in the shift register. Then when we press the Paste Data button the data is copied from the shift register to the Copied Data indicator.
Requirements
LabVIEW 2012 or compatible
1. Run the VI.
2. Press the Generate Data button to populate the Generated Data indicator
3. Highlight the data you would like to copy from Generated Data
4. Press the Copy Selected Data button
5. Select the cell in Copied Data Where you would like to start pasting data
6. Press the Paste Data to New Location button
Justin Parker
Product Support Engineer
