Example Code
Converting the Date/Time String in the Database Toolset to the SQL Query Format
Products and Environment
    Software
  • LabVIEW Database Connectivity Toolkit
  • LabVIEW
Code and Documents
Overview
You can use the attached VI to convert strings that are output as a date/time yyyy-mm-dd hh:mm:ss format from the "DB Tools Format Datetime Str VI" to a mm/dd/yyyy hh:mm:ss AM/PM format that is accepted by a SQL query.
Description
This can be used as a subVI in a larger application that uses the Database Connectivity Toolkit. The VI reads in a string input from the "DB Tools Format Datetime Str VI" and uses several "Search/Split String VIs" to break apart the current format. Then the VI concatenates all of the strings back to a single string output in a format that is accepted by a SQL query.
Requirements
  • LabVIEW 2012(or compatible)
  • Database Connectivity Toolkit (Only if used as a SubVI)
  1. Enter the desired string input on the front panel
  2. Run the VI
VI Snippet
Margaret Barrett
Digital Multimeters and LCR Meters
Comments
Todd S.
NI Employee (retired)
on
Could you include a screenshot of the code?  Thanks!
Todd S.
LabVIEW Community Manager
thad_tensentric
Member
Member
on
The AM/PM should be calculated if the hour is greater than 11, not 12.  12:00:00-23:59:59 is PM.
