Overview
This example takes an array of 1's and 0's and converts it into a single binary string.
Description
This VI takes an array of 1's and 0's and compares each element against a 1 to create an array of booleans. A Boolean Array to Number function is used to convert the array into a single number, which can be converted into a binary string using the Format Into String function.
Requirements
VI Block Diagram
There's no need for the FOR loop. The equals will take the array and scaler inputs and give an array out.
