Example Code
Converting a Space-Delimited File to Tab-Delimited (Spreadsheet) Format
Code and Documents
Overview
Reads in a space-delimited text file, and converts it to the tab-delimited format.
Description
 This VI reads reads in a space-delimited text file and writes it to a tab-delimited string. It also converts the data to a 2D array of doubles. If no path is provided to the File Path In control, it opens a File Dialog to select the text file to read from. the VI reformats the string by removing the spaces between each data column and replacing the spaces with one tab, so you can read the string as a spreadsheet string and then convert it to an array.
Hardware and Software Requirements
LabVIEW NXG 1.0 or compatible
  1. Run the VI.
  2. Navigate to the space-delimited text file and hit "OK".
Brandon Grey
Certified LabVIEW Architect
Contributors
