Overview
One code converts from a NI Scope Waveform to a NI RFSA waveform, while the other does the opposite.
Description
The NI-Scope driver and the NI-RFSA fetch functions both return a cluster with information on the waveform acquired. Unfortunately, these two clusters use different naming conventions and are therefore incompatible. There is often a need to convert the waveform info cluster from the NI-Scope Fetch VI to be compatible with the NI-RFSA waveform info cluster. The following VIs will convert NI-Scope waveform information to NI-RFSA waveform info and vice versa.
Requirements
1. LabVIEW 2012 or compatible
2. NI RFSA 15 or compatible
1. Fill the control with the desired data.
2. Select the Run button.
