Overview
Transform from an angle into a direction.
Description
Given an anemometer that measures wind speed with direction by returning the angle of the direction with a reference point at North, this code shows how we can transform this angle into a coordenate direction.
In this code, we asume O degrees as North, and each direction has a range of 22.5 degrees. Any change in halfway between two directions, the string switches.
Requirements
LabVIEW 2012 (or compatible)
1. Open the "Transform an Angle to a Direction LV2012 - NI Verified.vi"
2. Select the angle that can be displayed by the anemometer.
3. Select the Run button.
