Overview
These VIs demonstrate how to take a color or grayscale IMAQ image and transform it into a pixmap to be displayed on a 2D picture control.
Description
The project contains a VI called ImageToPicture that takes in an IMAQ image as an input. This image is then converted to an array that is flattened to a pixmap and then drawn to allow it to be displayed on a 2D picture control. The example demonstrates what colors are necessary as inputs for the Flatten Pixmap VI for an RGB or an 8Bit grayscale IMAQ image.
You may use the code as is within your project by dropping the ImageToPicture.VI as a SubVI or, if you will only be using grayscale images, just take the ImageToPicture_Grayscale SubVI.
Steps to Execute
Requirements
Software
LabVIEW 2010 or later with associated IMAQ driver
This is an interesting program.
May I ask what the situation is suitable for use IMAQ converted into 2D PICTURE![]()
