Overview
This example demonstrates how to convert a grayscale image into a binary image with the IMAQ Threshold VI.
Description
Some of the image processing functions are only meant to input binary images. However, if you image is not binary, you will have to convert it to utilize these functions. To do this, use an IMAQ Thershold (instead of IMAQ Cast) with a range value of 0,1. Then, ensure to change your palette on your Image Display to "Binary" to properly view the image.
Requirements
Software
- LabVIEW Base Development System 2012 (or compatible)
- NI Vision Development Module 2012 (or compatible)
- If running in a Real-Time context, you will need the LabVIEW Real-Time Module 2012 (or compatible)
Hardware
- No hardware is necessary to use this example VI
- Download and open the attached ZIP-file
- Open and run the VI
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
