Example Code
Convert Waveform Data to AVI
Products and Environment
    Software
  • Vision Development Module
  • LabVIEW
Code and Documents
Overview
The example demonstrates how to create a AVI file with a video of a waveform chart.
Description
LabVIEW features a AVI palette that can read or write a AVI video file toor from any IMAQ image data type.
With this AVI palette a video is created by capturing the image of a waveform chart indicator.
Requirements
 Software
  • LabVIEW 2012 Base Development System (or compatible)
  • Vision Development Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Select the path to save the generated AVI file to
  2. Select the desired frame rate
  3. Run the VI
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
Comments
BSampson
Member
Member
on
Hey Ricky,
Nice example if not all together practical.  One way that you could improve this to make it a little more scalable is to sync this with an event structure that only executed when the WF Graph was updated with a new value.  This would likely also be a little easier on the processor.
B Sampson
Ceres Bio Fuels
