Example Code
Convert Three Grayscale Images to an IMAQ Color Image with different methods
Products and Environment
    Software
  • Vision Development Module
  • LabVIEW
Code and Documents
Overview
The example demonstrates how to combine different IMAQ grayscale images to one IMAQ color image.
Description
To combine grayscale images to a a color image there are several methods available in the Vision Development Module:
  1. Use the 'IMAQ ReplaceColorPlane' function and directly combine 3 color planes to a color image
  2. Use the 'IMAQ ArrayToColorImage' function with the U32 Image Pixels array input
  3. Use the 'IMAQ ArrayToColorImage' function with the U64 Image Pixels array input
Requirements
 Software
  • LabVIEW 2012 Base Development System (or compatible)
  • Vision Development Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Select the method
  2. Run the VI
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
Zach C.
Field Engineer
Greater Los Angeles
Comments
MAILFERTSeb
Member
Member
on
Is it possible to do the same thing without the vision module?
Thanks for your help!
Sébastien
