Overview
This VI demonstrate the simple STL conversion tool is presented that allows the user to convert from binary to ASCII STL without ever leaving LabVIEW.
Description
Here is a brief description of the example:
This VI opens an STL file saved in binary STL format and converts it to ASCII STL format. An example binary STL file "cube.stl" is provided. The output ASCII file has been tested using Solidworks(R) 2015. The code has also been tested with other geometries and was successful. Curved objects with a large number of triangles will take longer to generate.
Additional information on the STL file format can be found on Wikipedia and on the block diagram in the example.
Requirements
VI Snippet
Worked the first time!
