Example Code
Convert Refnum to Numeric Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI converts an input Refnum to a I32 number and output this number.
Description
Many LabVIEW users have had trouble displaying the numeric data of the refnum datatype for debugging purposes. This example shows how using typecasting can be used to covert the refnum datatype into a readable form. Typically, when you create a control or indicator for the refnum datatype you will get an icon representation on the front pannel; this example shows how to display the refnum in a numeric indicator.
Requirements
  • LabVIEW 2012 (or compatible)
  1. You can change the way this number is displayed to the hexadecimal format by right clicking on the Numeric Indicator»Properties»Display Format»Type(hexadecimal).
  2. Run the VI, this will give you a numeric 32-bit integer representation of the refnum.
VI Snippet
