Example Code
Convert Media File in QuickTime Using ActiveX in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI converts media file to other format that is supported by QuickTime on your computer.
Description
You can specify media file that is supported by QuickTime. After executing the code, it will launch QuickTime on your computer and opens dialog box to specify the location of converted file. There is another sample code that uses embedded QuickTime control and converts the file without launching QuickTime. This is particularly useful if you do not wish to launch QuickTime separately.
Requirements
  • LabVIEW 2012 (or compatible)
  • QuickTime 7.7.8 (or compatible)
  1. Unzip the attached library to your computer
  2. Open the VI "Launch QuickTime and Convert to Other Format 2012 NIVerified.vi" in “Convert Media File in QuickTime Using ActiveX in LabVIEW 2012 NIVerified.llb”
  3. Enter media file location
  4. Specify media format to convert to
  5. Run the program
“Convert to Other Format and Create Export Preset in QuickTime 2012 NIVerified.vi” in “Convert Media File in QuickTime Using ActiveX in LabVIEW 2012 NIVerified.llb” converts media file to other supported format using embedded QuickTime control.
