Example Code
Convert Excel Time Stamp to LabVIEW Time Stamp
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
To demonstrate how to convert excel timestamp to LabVIEW timestamp.
Description:
This VI will covert Excel time stamp into LabVIEW time stamp.
Note -  Excell date format should be MM/DD/YYYY
If Date format is changed, you have to change in the code.
Instructions:
To implement this example:
  1. Define the path of the excel file. Make sure the excel time format is MM/DD/YYYY.
  2. Use range when necessary. Turned off by default.
  3. Run VI.
To execute this example:
  1. Install the required software.
  2. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
Hardware
Regards
Prabhakant Patil
Comments
Prabhakant_Patil
Member
Member
on
Kindly Write the Suggestions, Rating on this example
Prabhakant
Regards
Prabhakant Patil
Srikanth@Siri
Member
Member
on
you have done a good job it is useful for our project.....
Srikanth Kandagatla
Prabhakant_Patil
Member
Member
on
If you get any issue, then please let me know
Prabhakant
Regards
Prabhakant Patil
Abhi3345
Member
Member
on
nice work PC
Prabhakant_Patil
Member
Member
on
Thanks Dude
Regards
Prabhakant Patil
Prabhakant_Patil
Member
Member
on
Please click on like if you like it.
Your valuable suggestions are always welcome for the improvement.
Prabhakant
Regards
Prabhakant Patil
mikeporter
Proven Zealot Proven Zealot
Proven Zealot
on
I would like the code more if it gave the correct answer. As it is, the example Read Excel.vi returns values that (compared to the Excel file) are off by several hours. Did you correct for GMT, DST? Oh yes, the example Read_Excel_report.vi gives a different wrong answer.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Prabhakant_Patil
Member
Member
on
Is your excel file has the following format
Regards
Prabhakant Patil
mikeporter
Proven Zealot
on
Actually, I just opened your code and ran it against your excel file and the answers are wrong - the code is overly complex and doesn't handle GMT or DST properly. Also what difference does it make what the format in excel is? That isn't what you are reading.
The date column holds the integer number of days since 12/30/1899. To convert that into the number of days since LV's beginning of time (1/1/1904) you have to add 1462 and then convert to seconds by multiplying by 86400 - both of which you got right. But why the pointless reformatting that follows? Should I go into the problems with your subVI?
The time column from the excel spreadsheet contains the fractional number of days since midnight, multiply that by 86400 and you get the number of seconds since midnight. However you still have to account for both GMT difference and DST to get the time to display correctly in LV. To do that, take the number of seconds you are offset from GMT and if your location is on DST subtract 3600 from that number (the number of seconds in one hour). Now sum this result with the number of seconds since midnight and the number of seconds since midnight 1/1/1904 and convert the result into a timestamp using the To Timestamp function.
Mike...
LabVIEW Champion
Prabhakant_Patil
Member
Member
on
Hi Mike
Thanks for the suggestions.....
I will try this
Prabhakant
Regards
Prabhakant Patil
GriffinRU
Member
Member
on
I think you will find this link helpfull and to support Mike's comments Excel's format won't be an issue.
Enjoy,
-Artur
makadiakishan9922@gmail.com
Member
Member
on
MY PROJECT IS IMAGE PROCESSING BASED SHOPPING COUNTER USING WITH LABVIEW......BUT PRODUCT IS DETECT BUT ITS BILLING PROCESS IS NOT GENRATE....SO PLS HELP ME.........SO PLS GENRATE EXCEL FILE MEANS ONE TYPE OF BILL SYSTEM
shijianshisjian
Member
Member
on
pretty for my job
macroline
Member
Member
on
Can the file be read without the "read file" pop up message? I need to pass the file from the another vi and make read excel.vi  as a sub vi. Kindly help.
0Forest0
Member
Member
on
To correct convert time from excel to labview we shell save and read time zone whith timestamp.
