Example Code
Convert Celsius to Fahrenheit using an Expression Node using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
1. Overview
This VI shows a simple conversion from a temperature (DBL) in degrees Celsius to degrees Fahrenheit.
2. Description
The use of expression nodes is handy when doing conversions and simple operations. This example makes use of this structure to convert a Celsius temperature (DBL) to its value in Fahrenheit (DBL).
3. Requirements
NI LabVIEW Base Development System 2012 (or compatible).
4. Steps to Implement or Execute Code
  1. Download and run the VI
  2. If you want to convert to/from other units, replace the expression to the one that fits your conversion.
5. Additional Information or References
Convert Celsius to Fahrenheit  Screenshot.PNGConvert Celsius to Fahrenheit Screenshot.PNG
**The code for this example has been edited to meet the new Community Example Style Guidelines.**
