Overview
This example shows how to acquire raw data (I16 format) and convert it back to a scaled voltage value using two different methods in DAQmx. his example shows how to call a targeted Windows' application (i.e. Calculator) using the System Exec VI.
Description
This example shows how to acquire raw data (I16 format) and convert it back to a scaled voltage value using two different methods in DAQmx. The first method is manually scaling the voltage by using the equation "Voltage Reading = (binary reading/2^bit)*(Vmax-Vmin)". The second method uses the DAQmx Channel property node: AI Device Scaling Coefficients to convert the binary data to scaled voltage.
Requirements
Software
Hardware
Check out this article to learn more about scaling binary values: http://digital.ni.com/public.nsf/allkb/0FAD8D1DC10142FB482570DE00334AFB?OpenDocument.
