Example Code
Convert Array of Polynomials to Formula String Input
Code and Documents
Overview
This example provides a code snippet to easily create the 'formula' string input to some of the VI's in the Optimization palette, such as "Brent with Derivatives 1D.vi".
Description
It accepts an array of polynomial coefficients (doubles) as an input, and outputs the string formula. There is a brief example of how to use the resulting 'formula' string in one of the Optimization functions.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download and unzip the attached file to your computer.
  2. Open the VI “Array of Polynomial Coefficients to Formula String 2012 NIVerified.vi”.
  3. Input data to 'Array'.
  4. Run the VI.
VI Snippet
Ryan C.
