Example Code
Convert 32bit AVI to 8bit AVI using LabVIEW
Products and Environment
    Software
  • Vision Development Module
  • LabVIEW
Code and Documents
Description
Overview
This example VI shows how to convert a 32 bit avi video into a 8 bit avi.
Description
In some cases you may have a 32 bit AVI and really need an 8 bit AVI. If you use Vision Assistant you will notice that you are only able to make a 32bit AVI. To work around this you can use a VI to convert the AVI back to 8bit images.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • NI Vision Development Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached file
  2. Run the program
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
--Michelle
Comments
basm4
Member
Member
on
DO you know how to make this any more efficient?  my output file is >100x the size my input file.
