Example Code
Convert 2-d Array To One String
Code and Documents
Introduction
This C code will parse a data array and append all elements into on long character string. By default it does the parsing on a generated array but by easily modifying the source code you can change the array source.
Steps to Complete
Compile the C code in LabWindows/CVI and run the executable that is created.
Note
There is currently a problem with uploading a .c file to the NI Community. The file attached is the source code, simply change the extention from .txt to .c
Contributors
