Example Code
Controlling Units on a Waveform Chart using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Use this VI to change the units of your data.
Description
This example demonstrates how to change the units of your data and reflect those unit changes on the Y axis of a waveform chart using an implicit property node
Requirements
  • LabVIEW 2012 (or compatible)
1. Run VI
2. Select units to use
3. Looks changing data on waveform graph is changed
VI Block Diagram
Will
CLA, CLED, CTD, Former CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
