Example Code
Control from Cluster Event
Code and Documents
Overview
This VI demonstrates a method of triggering an event based on a cluster of controls.
Description
This VI has given a method of triggering an event based a cluster of boolean controls. This VI can be used with the cluster elements in any order, and with any data type for any cluster element (certain indicators and references would have to be rebuilt).
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the attached folder to your computer
  2. Open the VI "Event Cluster 2012 NIVerified.vi"
  3. Run the program
  4. Press the button you want
VI Block Diagram
Joel G
National Instruments UK & Ireland
