Overview
The example is to demonstrate how to generate a finite ram signal with a user-defined parameters
Description:
With a defined Analog Output from the user, a ramp signal would be generated with the help of the DAQmx in the waveform
and set by the user with the inquired parameters from the front panel of the VI
Steps to Implement or Execute Code::
To implement this example:
To execute this example:
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 15.0 or compatible
Hardware
cDAQ with C series Analog Output Module
Guillaume H.
National Instruments France
Can you make an exampple that doesn't need that extra modual toolkit
Hello, maybe is too late to send my question to this post but i will make it anyway. Maybe someone can help me.
Why the Voltage go up when the ramp is finish?
It can be evitable? i mean, if i put Initial voltage of 2V, and final voltage of 0, why can stay on 0?
Thanks for your help
Look at the "built array" node where the initial voltage is appended to the voltage ramp. If you remove that part and only wire the ramp to the Y terminal, it will stay at the last value.
Hi, can this code be used for the myRio and if yes how should I set the physical channel.
