Example Code
Concurrent FPGA Pattern
Code and Documents
Overview
A LabVIEW FPGA pattern for running N-channel FPGA cores independently with a focus on scalability and reduced resource utilization.
Description
Sometimes our projects require multiple instances of the same LVFPGA code in one FPGA bitfile.  A good example is RS232.  A project might require 10 channels of RS232 to run independently.  Once you have the RS232 core developed, scaling on FPGA can be tricky.  This pattern helps coordinating data to/from those cores, as well as using a minimal amount of resources.
Requirements
LabVIEW 2013 (or later)
LabVIEW/ LVFPGA
1.Unzip "Concurrent FPGA Pattern.zip"
2.Open ConcurrentFPGA.lvproj
3.Run Host code Testbench.vi.  This simulates the FPGA code.
Brian K.
