Example Code
Compare Strings Ignoring Case in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI exemplifies how to compare two strings ignoring if the characters are upper case or lower case.
Description
This VI uses the node named “To Upper Case” and the equal function to compare the two recently convert its strings. This could be really useful to compare values in which the which there are strings that are upper case and lower case.
Requirements
LabVIEW Base Development System.
1. Open the attached VI named “String Compare and Ignoring the Case LV 2012 - NI Verified.vi”.
2. Set the “String 1” and “Sting 2” controls using the values to compare.
3. Run the VI.
4. Check the Value of the “String Equal?” boolean LED.
Bryan H.
