Overview
This VI will compare two different 1D arrays and determine what elements the two arrays do not have in common.
Description
The logic compares the second array to the first array in a similar manner to source code control comparison. In other words, if you wire an old array and then a new array that has been changed from the initial array, it will return what elements have been added or removed.
Requirements
LabVIEW Base Development System (or compatible)
1. Set values on the Old Array and Modified Array controls
2. Run the VI
3. Verify which values were removed and added to the Modified array
