Example Code
Color Mixing in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Use this VI to create a color with R G B parameters
Description
This VI will mix different amounts of Red, Green and Blue to generate the color in the color box. This is done by taking three 8-bit unsigned numeric inputs, converting them to boolean arrays, combining the arrays and converting the resultant boolean array to a 32-bit unsigned integer.
Requirements
  • LabVIEW 2012 (or compatible)
1. Run VI
2. Select values for each of the color components (Blue, Green, and Red) between 0 and 255
3. The color box displays the resulting color mix
Block Diagram
Dan King
