Example Code
Classes in Script Using Diadem
Products and Environment
    Software
  • Diadem
Code and Documents
Overview
This DIAdem Script is an introduction to using classes in DIAdem.
Description
This example is a short introduction to using classes within DIAdem script.  There is an example clock layout for the report (Clock.tdr), and a short script, which defines a class, MyClock, with a subroutine that adds seconds to the clock as well as properties for seconds, minutes and hours.  The clock is initialized at noon and adds a new second to the time every second.
Requirements
Diadem 11 (or compatible)
  1. Copy Classes Script 2011 NIVerified.vbs and Clock.tdr in the same folder
  2. From the SCRIPT tab in DIAdem, open Classes Classes Script 2011 NIVerified.vbs
  3. Run the script
Cheers,
Kelly R.
