Example Code
Choose Data to Save in New TDMS File while Running
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This VI allows the user to select when he wants to save data to a TDMS file using a toggle switch while the program is running.
Description
This VI allows the user to select when he wants to save data to a TDMS file using a toggle switch while the program is running. A separate TDMS file is created for each separate section the user wants to save. In this example data is coming from a DAQ device.
Requirements
Software
  • LabVIEW 2012 or compatible
  • NI-DAQmx 9.5.5 or compatible
Hardware
  • NI Multifunction DAQ Device
  1. Download Save Multiple Files in One Session.VI
  2.
    Configure device and timing parameters.
  3.
    Use toggle swich to determine when to save data.
Rohan B
