Example Code
Checking and Unchecking Run-Time Menu Items
Code and Documents
This example VI uses a run-time menu from the CheckMenuItem.rtm file, created using the LabVIEW 6i Run-Time Menu Editor. The run-time menu contains a new menu, My Menu, which has six menu items. Two of the menu items remain unused, and the VI links the other four menu items in the following way: when you select a menu item, the VI marks the selected item with a check. You can only check one of the four menu items at a time. Selecting one of these four menu items automatically unchecks any previously checked menu item in the group.
Contributors
